In this lesson you will learn how to set up and process an SPH (Smoothed Particle Hydrodynamics) case.
You will work with the following features:
- SPH.
- Walls (import *.xgl, *.stl, and *.dxf Files).
- User Manual.
- 3D View Window.
- Eulerian Solution.
- SPH Boundary Interaction Statistics.
- Volumetric Inlet.
- Modify Fluid Material Compositions.
Simulation Files
Download the files here to follow the tutorial step-by-step.
