Transceiver Architecture - Part I — Lesson 1
This lesson covers the fundamentals of RF Transceiver Design, focusing on the architecture of transceivers and the key considerations in their design. The lesson begins with an explanation of the basic concepts of noise and linearity, and then delves into the architecture of transceivers, discussing both conventional and modern designs used in current RF systems. The lesson also explains the goals of receiver design, including amplification, variable gain, down conversion, and filtering. It provides an example of how a weak signal can be amplified and reconstructed, and discusses the challenges of implementing variable gain amplifiers at RF frequencies. The lesson concludes with a discussion on the importance of filtering in receiver design, and the difference between in-band and out-of-band blockers.
Video Highlights
00:25 - Introduction and aim of receiver: amplification
07:40 - Aim of receiver design: variable gain
12:06 - Aim of receiver design: Down conversion
18:49 - Aim of receiver design: filtering
23:29 - Channel selection and band selection
26:58 - Full duplex and GSM standards
32:54 - Basic heterodyne receiver architecture
Key Takeaways
- The primary goals of receiver design are amplification, variable gain, down conversion, and filtering.
- Amplification is crucial in receiver design to boost weak signals for further processing.
- Variable gain is necessary to accommodate the high dynamic range of signals, which can vary from very small to very large.
- Down conversion is important to reduce power consumption and facilitate efficient demodulation in the baseband.
- Filtering is essential in receiver design to suppress unwanted signals or 'blockers' that can degrade the signal-to-noise ratio (SNR).
- In-band blockers are unwanted signals within the desired frequency band, while out-of-band blockers are unwanted signals outside the desired frequency band.
