Facet Cleanup Tools in Ansys Discovery – Lesson 2
When you get an STL scan of a part file, it opens with problematic geometry regions, extra scan material, or missing regions altogether. If the part you are trying to reverse-engineer is truly important to get into workable geometry, you must find a way to properly clean and fix the mesh. This lesson will cover the ins and outs of the facet cleanup tools in Discovery software.
Lecture
Model Files
Download the accompanying Discovery Model file used in the video lesson here. Ansys Student can be downloaded for free here.
