Introduction to Power Dividers — Lesson 1
This lesson covers the fundamental properties of power dividers, directional couplers, and filters. It delves into the T-junction power divider, discussing both lossless and resistive variants, and the Wilkinson power divider. The lesson also explores waveguide directional couplers and the design of microwave filters by the insertion loss method. It introduces the concept of power loss ratio and how to design maximally flat and equal ripple low-pass filter prototypes. This lesson analyzes the Wilkinson power divider using even and odd mode excitation.
Video Highlights
00:30 - Contents and introduction to power dividers and couplers
04:38 - Application of power divider in array antenna
06:37 - Introduction to the T-junction power divider and its variants
11:18 - Lossless T-junction power divider and its S-parameters
20:54 - Explanation of the resistive power divider and its properties
32:29 - Introduction to the Wilkinson power divider and its properties
40:47 - Analysis of the Wilkinson power divider using even mode excitation
59:17 - Analysis of the Wilkinson power divider using odd mode excitation
1:02:04 - Summary of the properties of the Wilkinson power divider and its S-parameters
Key Takeaways
- Power dividers and couplers are passive microwave components used for power division or power combining.
- The T-junction power divider comes in two variants: lossless and resistive.
- The Wilkinson power divider is a special form of power divider that can achieve isolation between output ports while maintaining matched conditions at all three ports.
- Waveguide directional couplers and microwave filters can be designed by the insertion loss method.
- Power loss ratio is a crucial concept in designing maximally flat and equal ripple low-pass filter prototypes.
- Impedance and frequency scaling can be done to get bandpass and bandstop filters from the low pass prototype.
