Power Amplifier Design - Part II — Lesson 2
This lesson covers the design and classification of power amplifiers, focusing on the different classes of power amplifiers and their efficiency. It explains how power amplifiers are classified based on the conduction of the transistor and the power delivered to the load. The lesson also discusses the importance of impedance matching in designing power amplifiers and how it affects efficiency. For instance, in Class A amplifiers, the transistor remains in the active region for the entire cycle, while in Class B and C amplifiers, the transistor is on only during positive cycles. Class D, E, and F amplifiers use the transistor as a switch to improve efficiency.
Video Highlights
00:25 - Classification of power amplifiers based on transistor conduction
01:16 - Class A amplifier and its efficiency
08:13 - Class B power amplifier and its efficiency
12:27 - Class C amplifier and its efficiency
21:58 - Class D amplifier and its efficiency
25:22 - Class E amplifier and its efficiency
29:36 - Class F power amplifier and its efficiency
Key Takeaways
- Power amplifiers are classified based on the conduction of the transistor and the power delivered to the load.
- Class A amplifiers have the transistor in the active region for the entire cycle, leading to lower efficiency but better linearity.
- Class B and C amplifiers improve efficiency by having the transistor on only during positive cycles.
- Class D, E, and F amplifiers use the transistor as a switch, further improving efficiency.
- Impedance matching is crucial in designing power amplifiers as it affects the efficiency of the amplifier.
