Generating Files for ACT Machine Toolkit Data
In the ACT Machine Toolkit: Where are the files that contain the initial setup information and output data?
The input file data can be generated saving the toolkit settings. To do this, select the option: “Save toolkit settings to file” under “Toolkit Analysis Options.”
This file can then be uploaded in the toolkit and reused or modified. To do this, select the option “Prefill Settings using…” under “Project/Design Selection.”
The output data file (for the efficiency map data) is located the *.aedtresults folder. (See file “..EffMap.asol.”) You can also export the efficiency map points using RMB on top of the Efficiency Map by selecting Export.
