Ansys Scade One™ model-based embedded software development solution enables you to design models graphically, test behaviors, and automatically generate code. This video will walk you through the first steps, including creating a new project, declaring a module, and defining operators. You will be demonstrated how to debug an operator and generate code from a root operator, ensuring you have the foundational skills to start your work with Ansys Scade One Software.
0:28 - Create a Project
0:42 - Add a Module
0:51 - Add an Operator Definition
1:03 - Declare Inputs and Outputs
1:07 - Use the Quick Insert
1:10 - Implement an Addition
1:47 - Debug the Operator Behavior
2:23 - Declare a Code Generation Job
2:42 - Generate Code
