This lesson covers the principles of oscillator design, focusing on one-port oscillator design. It explains the methodology used in RFIC and microwave oscillator design, and how it can be applied to high-frequency oscillator design. The lesson also discusses the concept of input impedance, the role of the active device, and the importance of the input matching network. It further explains the conditions for oscillation and the Kurokawa identity for stable oscillation. The lesson concludes with a practical example of designing a transistor oscillator at 4 GHz using a common gate configuration.
00:25 - One Port Oscillator Design
07:06 - Power considerations: series resonator
10:31 - Operating point and stability
16:32 - Example on transistor oscillator design
23:22 - Role of Phase Noise in Oscillator Design
- Oscillator design involves understanding the input impedance, the role of the active device, and the terminating network.
- The conditions for oscillation involve considering the input impedance and the terminating network.
- The Kurokawa identity is a condition for stable oscillation, which involves the change in resistance with amplitude and frequency.
- Phase noise is an important aspect of oscillator design, which is generated due to noise in the active components.
- Practical application of these concepts can be seen in the design of a transistor oscillator at 4 GHz using a common gate configuration.
