This lesson covers the concept of noise in RF (Radio Frequency) systems, focusing on thermal noise and its impact on system performance. It explains the power spectral density of thermal noise, the relationship between noise and bandwidth, and the effect of temperature on noise power. The lesson also introduces the concept of 'white noise' and its frequency independence. It further delves into the calculation of noise power in a system with a noisy resistor and the trade-off between bandwidth and noise. The lesson concludes with a detailed explanation of the 'Y-Factor' method used to measure noise temperature and the concept of noise figure in RF systems.
00:25 - White noise and PSD
03:57 - How noise power is affected by the gain of an amplifier
06:07 - Y Factor method for measuring noise temperature
15:15 - Concept of noise figure in RF systems
22:21 - How to calculate the noise figure of a cascaded system
27:52 - Detailed walkthrough of an example calculating the noise figure of a cascaded system
- Thermal noise in an RF system can be represented by the equation 4KTR, where K is Boltzmann's constant, T is the absolute temperature, and R is the resistance.
- The power spectral density of thermal noise is independent of frequency, hence it is referred to as 'white noise'.
- The noise power in a system increases with an increase in bandwidth and temperature.
- The 'Y-Factor' method is used to measure the noise temperature in a system.
- The noise figure of an RF system measures the degradation of the signal-to-noise ratio (SNR) between the input and output of the system.
