Rayleigh Damping Model and Free Vibration — Lesson 3
This lesson covers the concept of modeling and solving a multi-degree of freedom (MDOF) system using MATLAB. The lesson begins with a review of the derivations and logic developed to model the MDOF system. It then moves on to solving an example, which involves defining the system, performing eigen analysis, and checking the mass and stiffness matrices. The lesson also explains how to calculate the proportionality constants Alpha and Beta, which are used to construct the damping matrix. The lesson concludes with a demonstration of how to transform the equations from the original space to the modal space, solve them, and then bring them back to the original space.
Video Highlights
Explanation of the two off system and its logic - 1:06
Description of the fast mass M1 connected to the spring and dashboard - 1:31
Explanation of the equation of motion in the case of free vibration - 2:28
Explanation of the transformation, Z to decouple the system - 4:34
Discussion on the orthogonality of the matrix - 5:21
Explanation of the assumptions made for the C Matrix - 5:52
Explanation of how to obtain constants from initial conditions in modal coordinate - 9:50
Discussion on the damping Matrix and how to find out Alpha and beta - 11:00
Explanation of how to solve the equation for Alpha and beta - 12:56
Demonstration of how to solve an example using MATLAB - 17:15
Explanation of how to find out the C Matrix and check if it is diagonalizing or not - 24:10
Key Takeaways:
- The logic developed for a two-degree of freedom system can be applied to structures with more degrees of freedom.
- The damping matrix can be constructed using the proportionality constants Alpha and Beta.
- The equations can be transformed from the original space to the modal space, solved, and then brought back to the original space.
- MATLAB can be used to model and solve a multi-degree of freedom system.
- Eigen analysis is a crucial step in solving the system.
