Natural Frequencies and Mode Shapes of MDOF System — Lesson 1
This lesson covers the derivation of the equation of motion for a multi-degree of freedom system. It starts with a discussion on the Lagrange equation and the concept of generalized coordinates. The lesson then moves on to an example of a two-story structure with different masses, stiffness, and damping coefficients. The instructor explains how to derive the kinetic and potential energy for the system and how to use these to form the Lagrange equation. The lesson also covers the process of idealizing the structure as a mass-spring-damper system and deriving the governing equations of motion. The lesson concludes with a discussion on how to solve these equations to find the natural frequencies and mode shapes of the system.
Video Highlights
Derivation of the equation of motion for a multi-degree of Freedom system - 0:55
Explanation of the Lagrangian equation and its components - 1:45
Example of a two-story structure with different masses, stiffness, and damping coefficients - 2:13
Explanation of how to derive the kinetic energy and potential energy of the system - 5:24
Development of the governing equation of motion for the system - 9:58
Explanation of how to derive the equation of motion using equilibrium conditions - 12:59
Proposal of a solution for the system's equation of motion and derivation of the characteristic equation - 31:15
Example of a two-story building with given masses and stiffness, and the calculation of its natural frequencies and mode shapes - 41:15
Key Takeaways:
- The Lagrange equation and the concept of generalized coordinates are fundamental to deriving the equation of motion for a multi-degree of freedom system.
- The kinetic and potential energy of a system can be used to form the Lagrange equation.
- A structure can be idealized as a mass-spring-damper system to simplify the derivation of the governing equations of motion.
- The governing equations of motion can be solved to find the natural frequencies and mode shapes of the system.
