power gains, stability, and the design of single-stage transistor amplifiers. It delves into the basics of low noise amplifier design and RF oscillators. The lesson also discusses the variety of transistors available for the design of microwave amplifiers and oscillators. It explains the concept of two-port power gain, stability criterions, and the design of single-stage transistor amplifiers. The lesson also provides a detailed explanation of the power gain, available gain, and transducer power gain of a network. It concludes with a discussion on the stability of amplifier circuits.
00:30 - Topics and introduction to microwave amplifiers and oscillators
04:23 - Basics of a two-port network and the two-port power gain
12:15 - Power delivered to the network and the power delivered to the load
35:35 - Power gain calculations
44:17 - Gain expression of the equivalent circuits
50:04 - Stability of the amplifier, including the conditions for unconditional and conditional stability
01:01:18 - Rollet's conditions and the mu test for determining the stability of a transistor or device
- Microwave amplifiers and oscillators are essentially two-port circuits.
- The power gain of a network is defined as the ratio of the load power and input power.
- The available gain is defined as the ratio of power available at the output of the network and power available from the source.
- The transducer power gain is the ratio of the power delivered to the load to the power available from the source.
- The stability of an amplifier circuit is usually frequency dependent.
- The Rollet's conditions are used to determine the unconditional stability of a transistor or device.
