Running a Simulation Using Ansys Lumerical Scripting — Lesson 1
Running a Single Simulation
In this video lesson, you will learn how to run a single simulation using Lumerical script commands. The simulation and script files used in the following video can be downloaded below:
Running Multiple Simulations Using the Job Manager
Lumerical allows running concurrent simulations using a job manager. In this video lesson, you will learn about the Lumerical script commands to manipulate job queues in the job manager. The simulation and script files used in the following video can be downloaded below:
Running a Parameter Sweep or an Optimization
Ansys Lumerical provides GUI tools for parameter sweep, optimization, Monte-Carlo analysis, and S-parameter analysis. In this video lesson, you will learn about the Lumerical script commands for parameter sweep and optimization. The simulation file used in the following video can be downloaded below:
