After running a simulation, the simulation will be in Analysis mode and simulation results can be collected
Datasets
Datasets group associated data into one object in which the measured data is referred to as an "attribute" and associated parameters are called "parameters."
Monitors return results that are packaged into datasets as well as raw data, which is un-normalized data that has not been packaged into datasets.
Plotting and exporting
Data can be visualized from the graphical user interface by right-clicking on the object containing data in the Objects Tree or
right-clicking on the data in the Result View window.
From the graphical user interface, data can be exported in the form of images or MATLAB files, or copied and pasted to a spreadsheet or text file.
From the script, data from the script workspace can be saved to Lumerical data files (.ldf), MATLAB files (.mat) or text files (.txt).
Analysis groups
Analysis groups can be created from the Groups button in the main toolbar or added from the Object Library to perform post-processing of monitor results to obtain custom results.
Result accuracy
Convergence testing should be performed to verify the accuracy of simulation results.
You are being redirected to our marketplace website to provide you an optimal buying experience. Please refer to our FAQ page for more details. Click the button below to proceed further.
