Buckley Leverett Front & Immiscible Flow Calculations — Lesson 6
This lesson covers the concept of flow through porous media, focusing on the Buckley Leverett front theory and the implications of gas phase presence and vapour liquid interaction. It explains the geometric construction of f_W versus S_W curve and the role of relative permeability in determining the volumetric flow of water and oil. The lesson also discusses the concept of formation volume factor in reservoir modelling and the importance of phase equilibria thermodynamics in determining the volume of gas under different conditions. It provides a comprehensive understanding of the continuity equations for oil, water, and gas in a porous medium.
Video Highlights
00:27 - Discussion on Immiscible Flow and Buckley Leverett Front
11:37 - Role of relative permeability in volumetric flow
21:30 - Understanding the concept of formation volume factor
27:18 - Writing continuity equations for oil, water, and gas
Key Takeaways
- The Buckley Leverett front theory is crucial in understanding the flow through porous media.
- The geometric construction of f_W versus S_W curve, determined by relative permeability, plays a significant role in calculating the volumetric flow of water and oil.
- The formation volume factor is an empirical method used in reservoir modelling to determine the volume of gas under different conditions, bypassing the need for rigorous phase equilibria thermodynamics.
- Continuity equations for oil, water, and gas are essential in understanding the flow dynamics in a porous medium.
