Exercises
As an exercise, consider the following problem of two spheres in contact. While our sphere-to-plate example used R2 = +∞, the following example deals with two finite radii.
- Compute the contact radius and compare with analytical results.
- Compute the maximum pressure that is induced along the z-axis.
- Check the validity of the numerical results by confirming the force reaction balance, and observe the effect of refining the mesh.
