Heat source models in welding II — Lesson 2
This lesson covers the concept of heat source models in welding processes. It delves into the intricacies of ellipsoidal heat source models, double ellipsoidal heat source models, and quadruple ellipsoidal heat source models. The lesson also discusses how these models can be used to calculate the maximum intensity of heat flux, estimate distribution parameters, and understand non-symmetric energy distribution. It further explores the adaptive heat source model, which eliminates the need for pre-defining heat source parameters. The lesson concludes with a brief introduction to the configuration heat source model and the conical heat source model.
Video Highlights
01:08 - Explanation of the double ellipsoidal heat source model
11:37 - Adaptive heat source model and its application in finite element based analysis
19:00 - Concept of hybrid heat source model for hybrid laser arc welding process
37:06 - Explanation of the adaptive heat source model
45:56 - Discussion on the conical heat source model
Key Takeaways
- Ellipsoidal, double ellipsoidal, and quadruple ellipsoidal heat source models are essential in understanding heat flux in welding processes.
- These models help in calculating the maximum intensity of heat flux and estimating distribution parameters.
- The adaptive heat source model is a dynamic model that adjusts according to the welding process, eliminating the need for pre-defining heat source parameters.
- The configuration heat source model and the conical heat source model offer alternative ways to represent heat sources in welding.
