Small Disturbance Potential Theory — Lesson 4
This lesson covers the concept of Small Disturbance Potential Theory, a crucial aspect of aerodynamics. It delves into the mathematical equations that govern this theory, explaining each term and its significance. The lesson also discusses the assumptions made in this theory, such as the small disturbance assumption and the thin aerofoil assumption. It further explains how these equations are simplified into linear equations for ease of use. The lesson also touches on the boundary conditions and how they affect the equations. For instance, it explains how the thickness of an aerofoil doesn't contribute to lift, and how pressure and velocity must be continuous off the body.
Video Highlights
00:21 - Introduction to the mathematical equations related to aero elasticity and their simplification.
05:17 - Discussion on the representation of the top and bottom surfaces of the wing.
28:11 - Explanation of the linearization of the equations and their simplification.
49:46 - Discussion on the impact of the thickness of the aerofoil on the equations.
65:33 - Explanation of the off-body boundary conditions and their impact on the equations.
Key Takeaways
- Small Disturbance Potential Theory is a crucial aspect of aerodynamics, which deals with the behavior of air as it interacts with solid bodies.
- The theory is governed by complex mathematical equations, which are often simplified into linear equations for ease of use.
- Certain assumptions are made in this theory, such as the small disturbance assumption and the thin aerofoil assumption.
- The thickness of an aerofoil does not contribute to lift, and pressure and velocity must be continuous off the body.
- Understanding these concepts is crucial for solving problems related to aerodynamics and aeroelasticity.
