This lesson covers the principles of electromagnetic transmission lines. It delves into the behavior of transmission lines when terminated in a load or another line, and the expressions for transmission line impedance in the presence of multiple reflections. The lesson also explores the transverse electromagnetic field structure, the circuit representation of a transmission line, and the derivation of the Telegrapher’s equation. It further discusses the concept of lossless transmission lines, transmission line boundary conditions, and the input impedance of transmission lines. The lesson uses examples such as the connection of two cables of different characteristics and the connection of equipment to the ground to illustrate these concepts.
00:12 - Introduction to transmission lines and their properties
08:47 - Lossless transmission line
14:31 - Explanation of transmission line boundary conditions
25:54 - Understanding of transmission line input impedance
30:32 - Special cases of input impedance of transmission lines
32:03 - Case study of transmission lines
- Transmission lines support a transverse electromagnetic field structure.
- The Telegrapher’s equation can be derived to understand the behavior of transmission lines.
- Lossless transmission lines have no attenuation or distortion.
- The boundary conditions of transmission lines are crucial when they are terminated in a load or another line.
- The input impedance of transmission lines can vary depending on the length of the line and the frequency.
