This lesson covers the theoretical and computational aspects of aerodynamic flows. It delves into the connection between theoretical exposure and computational activities in aerodynamic flows. The lesson discusses the impact of uniform velocity impinging on an airfoil at an angle of attack, the formation of a boundary layer, and the presence of viscous and inviscid regions. It also explores the assumptions associated with thin airfoil theory, potential flow, and Euler equations. The lesson further explains the concept of elementary flows as solutions of Laplace equation and the application of high lift devices in aircraft. For instance, it explains how deploying high lift devices during takeoff and landing phases of an aircraft increases the maximum lift coefficient.
02:42 - Explanation of the assumptions associated with thin airfoil theory, potential flow, and Euler equation.
07:19 - Introduction to the panel method, a numerical tool for solving two-dimensional potential flow past arbitrary geometries.
11:48 - Discussion on the effects of viscous dominated flows and the limitations of different models in capturing these effects.
24:43 - Explanation of the deployment of high lift devices during takeoff and landing phases of an aircraft.
34:16 - Discussion on the flow around the aircraft landing gear and the generation of noise due to pressure waves.
- Uniform velocity impinging on an airfoil at an angle of attack results in the formation of a boundary layer and a mix of viscous and inviscid regions.
- Thin airfoil theory, potential flow, and Euler equations come with certain assumptions that limit their application in certain scenarios.
- Elementary flows, which are solutions of Laplace equation, can be used to solve potential flow past arbitrary geometries.
- High lift devices are deployed during takeoff and landing phases of an aircraft to increase the maximum lift coefficient.
- The deployment of high lift devices also enhances the surface area, thereby increasing the net lift generating capability of the airfoil.
