Understanding DC Motor Operations — Lesson 7
This lesson covers the operations of a Direct Current (DC) motor, specifically a separately excited DC motor. The discussion includes the estimation of the armature resistance of a DC machine with a given rating of five kilowatt and 200 Volt. The lesson simplifies the calculations by considering the voltage to be 220 Volt. The main focus is on understanding the concept of armature resistance and its value in the context of DC motor operations.
Video Highlights
03:10 - Explanation of the power flow diagram of a DC machine
09:46 - Explanation of the use of stampings to reduce Eddy current loss
20:46 - Discussion on the gross torque developed by the machine
28:36 - Discussion on the back EMF and electromagnetic torque
Key Takeaways
  • The operations of a DC motor are complex and involve understanding various parameters.
  • A separately excited DC motor is used as an example to explain the operations.
  • The armature resistance of a DC motor is a crucial parameter, and its estimation is discussed in detail.
  • The calculations are simplified by considering the voltage to be 220 Volt instead of the actual 200 Volt.
