This lesson covers the comprehensive study of buckling in shells, with a focus on cylindrical shells. The lesson begins with a recap of previous weeks' topics, including composites, shell equations, theorem of surfaces and strains, and the development of governing equations for doubly curved shells. The instructor then delves into the importance of studying buckling in shells, highlighting the potential catastrophic failure of structures if not properly understood and designed for. The lesson also discusses the various reasons for buckling, including external pressure, concentrated load, geometrical imperfections, and residual stresses. The lesson concludes with a detailed explanation of the governing equations for buckling in cylindrical shells, including the consideration of non-linear terms and the application of boundary conditions.
01:56 - Buckling of shells and its importance in structural design
06:41 - Three stages of buckling: pre-buckling, buckling, and post-buckling
10:47 - Factors that influence the buckling of a shell
13:03 - Concept of bifurcation in buckling
20:12 - Buckling of composite laminated cylindrical shells
45:08 - Boundary conditions for buckling
51:19 - Solution for the governing equations for buckling
- Buckling in shells is a critical aspect of structural design, particularly in thin shells used for structural applications.
- Buckling can occur due to a variety of reasons, including external pressure, concentrated load, geometrical imperfections, and residual stresses.
- The governing equations for buckling in cylindrical shells consider non-linear terms and require the application of specific boundary conditions.
- The study of buckling in shells is not limited to theoretical understanding but also involves practical applications and experimental works.
- The buckling of cylindrical shells is a complex process, with a high mismatch between experimental results and theoretical results due to small imperfections in the cylinder.
