This lesson covers the efficiency aspect of amplifier design, focusing on the balance between power consumption and output quality. It explains the different classes of amplifiers based on the conduction angle of the transistor. The lesson also discusses the concept of balanced amplifiers, which can achieve broad band impedance matching and gain matching. It further delves into the topic of frequency compensation, explaining how filters can be used to maintain constant gain across different frequencies.
00:15 - Introduction
01:32 - Different classes of amplifiers
04:35 - Operation of Class A amplifier
06:43 - Operation of Class B & C amplifier
10:35 - Aspect of frequency compensation
12:29 - Concept of a balanced amplifier/a>
- Amplifier efficiency is a balance between power consumption and output quality.
- Amplifiers are classified into Class A, B, AB, and C based on the conduction angle of the transistor.
- Balanced amplifiers can achieve broad band impedance matching and gain matching.
- Frequency compensation can be achieved by using filters to maintain constant gain across different frequencies.
- Class A amplifiers, conducting for the entire 360-degree phase variation, are typically used in low noise amplifiers.
