This lesson covers the fundamentals of digital modulation schemes, focusing on the concepts of Inter Symbol Interference (ISI), pulse shaping, and various modulation methods such as Phase Shift Keying (PSK), Frequency Shift Keying (FSK), Quadrature Phase Shift Keying (QPSK), and Quadrature Amplitude Modulation (QAM). It explains how these methods are used to reduce ISI and bandwidth, and increase data rate. The lesson also discusses the importance of linear power amplifiers in these modulation schemes. For instance, it explains how Quadrature Amplitude Modulation (QAM) can be used to achieve high data rates in limited bandwidth, a technique used in current 802.11 standards.
00:25 - Pulse shaping methods and the use of the sync function
03:43 - Explanation of signal and FSK constellation in digital modulation
09:07 - Error vector magnitude (EVM) in digital modulation
12:25 - Quadrature Phase Shift Keying (QPSK)
23:23 - Explanation of Quadrature Amplitude Modulation (QAM)
28:24 - Need for linear power amplifiers in QAM
- Inter Symbol Interference (ISI) is a common issue in digital modulation which can be reduced using pulse shaping methods.
- Different modulation methods like PSK, FSK, QPSK, and QAM have their unique advantages and applications.
- QPSK and QAM are advanced modulation schemes that help in reducing bandwidth and increasing data rate.
- Linear power amplifiers are crucial in modulation schemes, especially in QAM, due to the changes in amplitude.
- Error Vector Magnitude (EVM) is a measure of the deviation of the constellation points from their ideal positions in digital modulation.
