Bandwidth Estimation Using Short Circuit — Lesson 3
This lesson covers the bandwidth estimation techniques and the method of short-circuit time constants. It explains how to determine the bandwidth of a network by pulling out one capacitor and killing all other capacitors in the network. The lesson also discusses the method of open circuit time constants and how it helps to identify the zeros of a circuit. It further explains how to identify which capacitors contribute to poles and which contribute to zeros. The lesson concludes with the introduction of a new module on white band amplifier design and the challenges associated with handling circuits with both inductors and capacitors.
Video Highlights
00:24 - Introduction and recap of previous lesson
16:39 - Introduction to the next module: White band amplifier design
36:12 - Load network
45:25 - What happens when the location of the poles changes
50:17 - Calculation of the bandwidth using the value of eta
Key Takeaways
- The method of open circuit time constants is used to estimate the bandwidth of a network.
- To identify the capacitors responsible for poles and zeros, one must understand the impact of opening or shorting the capacitors on the circuit's performance.
- The method of short-circuit time constants helps in determining the bandwidth of a network.
- The method of open circuit time constants helps to identify the zeros of a circuit.
- It's crucial to identify which capacitors contribute to poles and which contribute to zeros in a circuit.
