This lesson covers the concept of axial vibration of bars, a common occurrence in many situations. The lesson begins with an explanation of the axial vibration of bars, followed by a detailed discussion on deriving the equation of motion for axial vibration using Newton's Second Law and the energy principle. The lesson then delves into the model analysis for axial vibration, explaining the purpose and process of finding natural frequencies and mode shapes. The lesson also discusses the decoupling of equations of motion and the solution of time-dependent generalized coordinates. The lesson concludes with an explanation of free vibration and forced vibration cases, and the application of Hamilton's principle to derive the equation of motion and boundary conditions.
09:12 - Equation of motion for a bar with damping and external force.
26:41 - Modal analysis for the axial vibration of a bar.
35:22 - Free vibration case for a bar fixed at one end and free at the other.
45:48 - Forced vibration of a bar, including the decoupling of the equation of motion.
51:14 - Free vibration response of a damped model with given initial conditions.
- Axial vibration of bars is a common occurrence and can be analyzed using Newton's Second Law and the energy principle.
- The model analysis for axial vibration involves finding the natural frequencies and mode shapes.
- The equations of motion for axial vibration can be decoupled using the superimposition of modes and orthogonal conditions.
- The solution of time-dependent generalized coordinates is similar to the solution of a single degree Freedom system.
- Hamilton's principle can be used to derive the equation of motion and boundary conditions for axial vibration.
