Tentang Instruktur
Karthik
LinkedIn
Karthik Remella
Ph.D. in Mechanical Engineering, University of Cincinnati
Multiphase Flows, Heat-Transfer, Turbulence, Fluid-Structure Interaction
Kalyan
LinkedIn
Kalyan Goparaju
Ph.D. in Aerospace Engineering, Ohio State University
Aeroacoustics, Aerodynamics, Turbulence, Numerical Methods
“Weiyu"
LinkedIn
Weiyu Cao
Ph.D. in Mechanical Engineering, University of Michigan - Ann Arbor
Heat Transfer, Combustion, Aerodynamics, Turbulence
Rahul
LinkedIn
Rahul Kumar
Ph.D. in Aerospace Engieering, University of Cincinnati
Compressible Flow, Air-Breathing Propulsion, Pulse Detonation Engine
