The file demonstrated in this video can be set up by following the demonstration in the previous lesson, Setting Up the Simulation, or you can run the following script file from the script file editor to set up the same simulation.
FDE_my_first_simulation_setup_script.lsf
Once the simulation is set up properly, you need to run the simulation to calculate the modes of the waveguide. In this video, we will demonstrate how to run the simulation using the SOI rib waveguide example.
