setemeanalysis: Sets calculation parameters in EME analysis window
getemeanalysis: Gets calculation parameters in EME analysis window
emepropagate: Propagates fields and calculates S-matrix results. This is equivalent to the “eme propagate” button in the graphical user interface.
setemeanalysis("group spans",[1e-6;1e-6;1e-6]); # set group spans to 1 micron
emepropagate; # propagate eme
emesweep: Runs propagation sweep. This is equivalent to clicking the “eme sweep” button in the EME Analysis Window.
getemesweep: Gets the user S-matrix result from a propagation sweep.
Note: same commands are used to run the mode convergence sweep and get its results.
# set propagation sweep settings
setemeanalysis("propagation sweep",1);
setemeanalysis("parameter","group span 2");
setemeanalysis("start",10e-6);
setemeanalysis("stop",200e-6);
setemeanalysis("number of points",10);
emesweep; # run propagation sweep tool
S = getemesweep('S'); # get propagation sweep result
# plot S21 vs group span
s21 = S.s21;
group_span = S.group_span_2;
plot(group_span,abs(s21)^2);
