5G Handset Simulation Using Ansys HFSS 3D Layout — Lesson 7
This lesson covers the simulation aspects of a connector and an antenna in HFSS 3D layout and their analysis. The outline for this lesson is as follows:
Restore archive file comprising setup and analysis >> separate HFSS MCAD designs for connector and antenna >> model modifications >> add ports >> add solder balls >> add phone case >> add HFSS solution setup >> run simulation and view results.
Download the accompanying simulation files here.
