This lesson covers the fundamental aspects of amplifier design and stability in transceiver systems. It delves into the basic components such as inductors, capacitors, and resistors, and how they are drawn on a chip. The lesson further explores the importance of amplifiers in transceiver design, particularly low noise amplifiers and power amplifiers. It also discusses the significance of stability in amplifier design, explaining how to achieve it using S parameters of transistors. The lesson provides a detailed explanation of signal flow graphs, stability circles, and the use of resistive loading to ensure amplifier stability. For instance, it uses an illustrative example of a two-port network to explain the concept of stability.
00:25 - Introduction to amplifier design and signal flow graph
08:44 - Mason semantic
13:37 - Input reflection coefficient of loaded 2 port network
17:58 - Stability of amplifier and input and output stability circles
21:41 - Input stability circles
27:35 - Output stability circles
33:11 - New criteria for 2 port unconditional stability
- Amplifiers, particularly low noise and power amplifiers, are crucial in transceiver design.
- Stability is a vital aspect of amplifier design to prevent oscillation.
- S parameters of transistors are used in amplifier design.
- Signal flow graphs are useful in understanding the equations and stability of amplifiers.
- Stability circles help differentiate between stable and unstable regions in amplifier design.
- Resistive loading can be used to ensure amplifier stability.
