This lesson covers the process of using Ansys Fluent® fluid simulation software to solve for velocity components and pressure at cell centers. It explains how to specify other quantities to be calculated from these values, such as the drag coefficient. The lesson also discusses how to set up report definitions, specify reference values, and adjust the criteria for convergence. It further elaborates on the iterative process to get the cell center values of the primary unknowns and how to initialize these values. The lesson concludes with the process of running the calculation and verifying the convergence of the solution.
