In the Pre-Analysis step, we'll review the following:
Before starting a CFD simulation, it is always good to examine the governing equations underlying the physics. In this case, although we have additional complexities such as pulsatile flow and non-Newtonian fluids, the governing equations are the same as for any other fluids problem. The most fundamental governing equations are the continuity equation and the Navier-Stokes equations. Here, let's have a quick review of the equations.
Continuity Equation:
However, since we are considering only the steady case, the time-dependent term is zero. Thus, the continuity equation above can be further simplified in the form below:
The Navier-Stokes Equation is written as follows:
Wall:
The easiest boundary condition to determine is the artery wall. We simply need to define the wall regions of this model and set them to “wall.” From a physical viewpoint, the “wall” condition dictates that the velocity at the wall is zero due to the no-slip condition.
Inlet:
Here our inlet velocity will be a constant 0.315 m/s. This was chosen to give us a Reynolds number of 600.
Outlets:
The systolic pressure of a healthy human is around 120 mm Hg, and the diastolic pressure of a healthy human is around 80 mm Hg. Thus, taking the average pressure of the two phases, we use 100 mm Hg (around 13,332 Pa) as the static pressure at the outlets.
