This lesson covers the concept of flow through porous media, focusing on the basic characterization and parameters of porous media. It delves into the theories of flow through porous media, starting with understanding mass continuity. The lesson explains the continuum assumption, where the porous media is treated as a homogeneous set. It discusses Darcy's law and its application in determining the permeability of the media. The lesson also explains how to measure porosity and permeability, and how these parameters can vary within different sections of the media. The concept of mass continuity in fluid mechanics is also discussed, with a focus on how it applies to porous media.
01:03 - Explanation of the continuum assumption
03:36 - Explanation of how to measure permeability
10:08 - Discussion on how to measure porosity
18:10 - Explanation of mass continuity in fluid mechanics
29:37 - Application of mass continuity to porous media
- Porous media is treated as a homogeneous set under the continuum assumption.
- Darcy's law is used to determine the permeability of the media.
- Permeability and porosity can be measured using various methods, and these parameters can vary within different sections of the media.
- The concept of mass continuity in fluid mechanics applies to porous media, and it is used to understand the flow through the media.
