Use Cases:
- Explain this function.
- Refactor this code to improve performance.
- Adapt this script using numpy.
Key insights:
- Copilot uses what you have open.
- It does NOT fully understand the whole repo automatically.
Tip: Open multiple relevant files.
Best practices
- Boilerplate code.
- Quick scripts.
- Code exploration.
Limitation
- Incorrect or hallucinated code → always review.
- Security / sensitive data.
- Hidden assumptions.
Copilot is not going to make you a better engineer, but it can make you way more efficient
