The option you select is wrong. Harmonic Acoustics Analysis quantifies acoustical characteristics including pressure distribution, sound power, the pressure gradient, and particle velocity at various frequencies, applied using equations for pure acoustics and fluid-structure interactions. To get more info on this, click here.
The option you select is right. Harmonic Acoustics Analysis quantifies acoustical characteristics including pressure distribution, sound power, the pressure gradient, and particle velocity at various frequencies, applied using equations for pure acoustics and fluid-structure interactions. To get more info on this, click here.
