Simulation Quiz
Total Available Time - 45 mins
Total Number of Questions - 4
Times up!
5G Cross Dipole Antenna Array — Simulation Quiz
Total number of questions - 4
Simulate the following cases using Antenna Toolkit before starting the quiz. For each case, create a new design and rename it.
Case A: Inset fed patch antenna - solution frequency 3.6 GHz, substrate material duroid, substrate thickness 0.2 cm.
Case B: 1x4 Inset fed patch antenna with finite array wizard using case A.
Case C: Apply beam steering of 45 degree to "ScanAngleTheta" variable to Case B.
1 / 4
In case C, what is the range in which the maximum value of the gain lies?
2 / 4
In case B, what is the frequency range in which the antenna array has a minimum S11 value?
3 / 4
In case B, what is the magnitude of array factor?
4 / 4
In case A, what is the range in which the peak directivity lies for 3.6 GHz frequency?
Your score is
0%
